noob with a project boat, need advice
ryanstandley
Hi,
I recently adopted a neglected 17' Reinell runabout. The hull is very solid, but the interior is rough and someone did a really poor job of painting it at some point, and it's peeling and flaking badly. I was told that the motor was a 140 Mercruiser, but in doing a bit more digging I think it's a 120. The motor had the head and manifolds pulled off and sat that way for quite a while, so the bores are rusted. I'll be looking up the serial numbers on the motor and stern drive this week to be sure of what I've got.
Now, for the questions. I've started disassembly of the interior and hardware to give the thing a nice pressure wash to degrease and hopefully remove the poorly applied paint. I plan to then sand the gelcoat and either repaint with epoxy or just polish it depending on it's condition. The inside of the hull appears to be raw fiberglass. Is there any reason I should not paint the inside while I've got it stripped?
The engine, as I mentioned earlier is siezed and a bit rusty. How do you guys lift the engine from the boat after it's been disconnected? The boat's on its trailer, so it's pretty high for a standard automotive engine picker. I may rebuild, or replace the motor depending on how it looks when I tear it down. I've rebuilt motorcycle engines, and done a lot of auto work so I feel pretty confident I can save it if it's a decent core.
Thanks,
Ryan
Re: noob with a project boat, need advice
A Tree Limb,........ Garage Door Header, or Rafters.... A Tractor Bucket,.....
That little I-4 will only weigh Maybe a couple Hundred Pounds,.......
A couple of Football Player Friends could probably Toss it Out........
sdunt
Sorry, you are over the quota for number of questions per post :)
Pressure washing is good and a great way to see how much paint will come off.
Sanding Gelcoat BAD! If you want it to shine again. you can use paint strippers on gelcoat. There are some that are specifically for boats, but one of the milder Orange stripper would probably work.
Here's an article about polishing OLD Gelcoat :
http://www.fiberglassics.com/mfg/restoring_glossgelcoat.htm
This was on a 1965 boat by the way.
Yes, paint the interior, rustoleom, or gloss porch and deck enamel. Because its 'above the water line' you can use paints from the Home Depot on the interior. And latex's work fine. Just keep in mind that latex does not totally cure for 14 days. Its still a little soft during that time..
ryanstandley
Thanks for the input guys, I'll see what I can come up with to pull that motor. Regarding sanding the gelcoat, I thought wet-sanding with a fine grit was an accepted way to get back to a clean level surface to buff out? Also, I was thinking of hitting the interior with truck bed liner in white? I'm planning on using the boat for fishing, so it'd be nice to have a low maintenance nonslip surface under foot. Think I just exceeded my questions per post quota again, sorry ;-)
RubberDuckie
A properly done, gentle and progressively finer grade, wet sanding job produces mirror like finishes. Go for it.
