Noodles as stringer bedding? Comments please
kryan2
Is it feasable to use a pool noodle cut in half lengthwise as a bedding for stringers? It would be about 1/4 inch thick, foam that wouldn't hold water and easliy trim to size.
Would resin and glass "mold' around it to hold it all togeher?
I'm redoing a 14' McKee Craft and my "homemade stringers" are going in this week...then 4lb pour foam.
Hmmmm........
drewpster
Re: Noodles as stringer bedding? Comments please
My only concern would be that the noodle would quickly deteriorate and leave a dead space under the stringer. Any dead space can collect water and start the rot all over again. I like construction adheasive. It stays flexible, and it wont melt away.
RBagdon
Best bet would be to mix up some peanut butter (Resin, chop strand and Cabasil) and bed your stringers in that. The excess is used to cove the corners to make it easier to glass.
jonesg
I like and use both, peanut butter and PL , depending what I have the most of but the PL is easier and probably cheaper.
MTboatguy
I would not do it..
tschmidty
Not a chance, glue it or epoxy/resin peanut butter mix.
TriadSteeler
Definitely not. I zip tied Noodle sections to the bike rack on the back of my camper last year to prevent scratching. After 3 months in the weather they actually turned to dust at the slightest touch.
rickryder
PB mixture is the way to go....keep the noodles for the pool :)
