Re: Normal temperature for a 5.7 Merc?
OK - so I took it out this weekend and tried a number of the things mentioned above. The T-stat housing only registered about 112 on the infared thermometer, as did the port heat riser. The Starboard riser read 123. All of this is while the dash guage showed 170 - 175. Think I should temporarily install a cheap mechanical guage from the auto parts store to see if maybe the dash guage or sending unit is the culprit? Note that once the temperature reached that level, it didn't fluctuate at all either at an idle or high RPM's.
