Not charging 1993 mariner 115 4cyl.
grc1224v
have a 1993 115hp 4 cyl. mariner thats not charging<br /><br />where do i look<br /><br />thanks :confused:
WillyBWright
Re: Not charging 1993 mariner 115 4cyl.
Welcome to iboats.<br /><br />At the voltage regulator. If you have loose or corroded battery connections, that'll take it out. So will accidentally connecting the battery backwards or switching a battery switch (if your boat has one) while the motor is running.<br /><br />The other major component is the stator under the flywheel. The charging part of those hold up pretty well. The vast majority of charging problems are at the regulator, but a bad stator isn't impossible.
