Hi. I'm working on this boat I bought last fall. It was a stern drive to I/O conversion, but the guy sold it before he finished the job. So it's a project boat you could say.<br /><br />I just checked the angle of the transom and it's only 6 degrees from verticle. The recommended angle is 12 plus or minus 2 degrees. Will installing a transom wedge fix this problem? I would think even with a transom wedge, forward movement of the prop during trim will still be limited, since the space between the bottom of the transom and the lower unit will stay the same no matter how I angle the motor bracket. Won't that restrict forward trim even with a wedge?<br /><br />Does this make sense?
<br /><br />Maybe I should just leave it the way it is and go with a separate trim system? <br /><br />Any ideas?<br /><br />Thanks,<br />Dennis
