i have a 1975 mecrury 85 hp motor.. i just got the boat been messing around with it today i checked the spark on all 4 cyl's compression seems good but lower 2 cyl not firing if i change the wires around the bottom one will fire..i only changed the one wire but it made it fire.. any ideas r if u need more info let me know iam closer then i was when i started.. i need to add to this all the plug wires on the motor u can pull them right off the copper wires isnt connect to the lead in the cap and also i see the ones that r not fire r arcking all over the out side of the plug
