Proline3250
- Sep 26, 2021
- 7
I have a 1998 pro line 3250 with 7.4 MPI the port engine was not firing replaced the coil and the module inside of the distributor the distributor cap and rotor button started right up no problems three days later no fire again checked both coil and module seem to be fine Took the coil wire off of the starboard engine which runs still no fire at coil wire I have power at both wires with the ignition in the on position at both the distributor and the module inside of the distributor cap disconnected the tack still no fire at the coil wire I am perplexed. Tachometer doesn’t show any movement when cranking the engine.
