not getting fuel
Lawnpro979
hey guys,
I gotta head scratchier here, VP 4.3 Carbed Been sitting for 2 yrs. I removed the fuel. new battery, new water fuel separator, Put about 8 gallons of fresh fuel in her , cant get fuel to carb. So I removed the pump benched tested it, works just fine.
Checked fuses, checked relay all is good......at hot on relay I'm getting 12.9 V
We pulled the fuel line to pump to suck the fuel out, so this is telling me fuel is making it to the pump
Question. When does fuel pump engage? when starter is activated ?
is there a 2nd sorce of power to it after its running?
is there any power to it just with key on ?
thanks again.....
alldodge
Being a carb motor I'm going to assume its a GL, but a GL what?
The GL uses feed from the Key switch (yellow/Red) to energize the start assist relay and the fuel pump relay. The feed to energize the FP relay goes thru a diode. If the diode opens then the relay is not energized.
Once the motor starts and the alternator turns ON, then power is feed thru another diode to keep the pump running
This is the GL-C/D
no, you need to troubleshoot.
if the pump works on the bench and not in the boat, something is wired wrong.
alldodge
Look at items 23 (Diodes) in the drawing above. One is connected to a Green wire and the other is connected to a Yellow/Red wire. The Y/R wire changes to Orange after the diode. Both Grn and Y/R wires connect to the same point on the relay
Use a voltmeter and connect the positive lead to the relay where the Org and Grn wires connect. Crank over the motor and see if you get 12V
If you do not get 12V, then find the diode is bad
If you do get 12V then connect meter to relay pin going to the pump
If you do get 12V when cranking then the ground connection on the pump is bad
If you do not get 12V at the pump when cranking then the relay is bad
emoney
By the way, did you fill the fuel water separator cannister with gas before reinstalling? If so, to confirm the bulb is at least pulling it to the motor, spin it off and make sure it's still in there.
I missed this once and almost went all through the entire fuel system before I figured it out, lol. So now, I at least remind people just in case so they don't through all that trouble.
Lawnpro979
ok got it thanks .....Also NO I did NOT prime the water fuel separator before installing it.......I was going to try that today....
Lawnpro979
ok got it............. Everything wasn't making sense I checked everything
Took the pump back off bench testing it again....nothing but humming....... Messed with it for a few. got it to work... Left it on bench. start stop let it run for 1/2 a day.....it seems fine....
put it all back together and WOO HOO, she's working
Running like Crap-o-la I can foresee new plugs and possible a carb kit...
I was a little Leary of using the pump the only thing I can think of is that it had stuck... maybe it had corrosion in it and bumping it cleaning it did the trick that's why I let it run so long.....
after 2 years of sitting I was surprised at how fast it started up...
thanks everyone
