Great, thanks for the info. <br /> I have an '84 Merc '50 and it stoppped peeing. I took off LU off and cleaned out the tube. I got alot of junk out of it and put the LU back in. Ran it and it was peeing. Put it in gear, no problem. Then shut it down and hooked up my gear cables and all. Started it up again and ran it. Fine...put a load on it, then it sounded different and no more peeing. Took down the LU and checked all the lines and tube. Clear. My father-in-law says to check the thermostat. Is there a thermostat and is there a chance it's that? Thanks in advance.<br /> <br /> GreatSouthBay_Boater
