Not rev up bogs out
clark8261
Hi hope someone can help me on here I’ve recently bought a quicksilver 705 active 3.0L 2015 with 200hrs on when I go to rev it it bogs out like timing or fuel mixture
Haha now I’ve changed the carb inlet manifold plugs fuel pump distribution system coil but still bogs I’ve tried running straight from fuel can with still no joy I could get it to go into base timing with old distribution system but dose not seem to make any difference with new one on at one point the engine just picked up and ran perfect rev was ok stopped like that a day or so took it up the river and went back to running crap and not reving
All parts are new it has my head battered
Thanks in advance
Ayuh,..... Welcome Aboard,..... Which distributor does it have,..??
Did you change the carb, or the intake manifold, or both,..??
04fxdwgi25
Check the fuel pressure. Could be a plugged fuel filter or a bad anti-siphon valve at the fuel tank that could be limiting fuel available to the carb. Also check that the fuel tank vent is clear (try running with the fuel fill loose / open to see if tank is vented).
clark8261
Hi thanks it has the est distributor and I changed both carb and manifold and fuel pump as I said I was standing scratching my head the engine picked up and ran smoothly now it’s gone back to running lumpy and not rev
clark8261
Hi thanks for responding it has new fuel pump on and I’ve ran it from a separate tank only thing I haven’t changed was the wiring that came with new distributor as it is all taped in I changed the jumper wire from coil but I can’t get this new distributor to go into base timing mode I’ve joined the 2 at distributor and 2 at at intersection switch
clark8261
Hi I’ve just done another check can you help me with this with my timing light on the digital read out on the rpm is all over jumping from 800 1600 2500 I’ve also noticed the plug from coil going to distributor both wires are live is this correct
clark8261
I’ve just came across that I’m getting 15v to the batteries and to the coil which will be sending the distribution system crazy I’ve disconnected the alternator and still getting 15v when engine is running
