Not Shifting into Forward
pdeblois
1990 Lucat Twister<br />Mercruiser 185, alpha one<br />Morse Incom Shifter<br /><br />Shifts OK in reverse but nothing, but a little grinding, when I try to go forward. Is this a cable problem (reverse is working fine). Does it need ajustement or a new cable.<br /><br />Thanks
pdeblois
Re: Not Shifting into Forward
Thanks Qystan,<br /><br />I see that the URL talks about symptoms related to engine dying when shifting. Are those adjustements good for all situation(My engine doesn't stall)?
qystan
Yes, the adjustments are the same. The engine dying problem is either a bad cable or badly adjusted cable. In your case, the adjustment is biased towards reverse.<br /><br />You can try shortening the throttle box cable by turning the barrel end. Try 1-2 turns each time. Note that the whole thing may go out of whack, in that case start from the beginning as described in the FAQ and you should be fine.
pdeblois
Thanks again Qystan, that did the trick. Off to the lake and hopefully I won't have to take it out of the water after only 10 minutes.
pdeblois
Well a nice day at the lake :cool: . Thanks again Qystan and the Iboats site. Without you it would have been sunday without boating and monday at the shop $$$. :(
