TwoBallScrewBall
- Sep 14, 2003
- 1,695
See later post......<br /><br />Added some more details here, sorry for the bump but I'm in the middle of the job and need to get it back together as soon as i can...<br /><br />OMC cobra 3.0, 1988... Well I probably don't want the answer to this question, but oh well. I noticed that even though my shift/throttle lever was in neutral my outdrive wasn't. I pulled the drive OK but the shift shaft going into the lower unit of the drive is stuck in reverse. Won't move. I tapped it with a screwdriver a bit and it moved very slightly, and the drive is now in neutral, but I still can't move the shift shaft by hand. The drive feels very smooth in gear and in neutral but the damn lever won't move. I'm about to go get buried in my shop manual but if you guys have suggestions or ideas just shout. <br /><br />Thanks.
