Not starting everytime
1983rinker
I have new starter, igntion, and solenoid. Today when I was out I turn key off. And would not start up, So I jump it. Then when at dock I tryed key agin and it worked twice. When I got back to my boat storage I try agin, and nothing. Could this be a lose wire?
jerryjerry05
Re: Not starting everytime
Sounds like a solenoid problem.Maybe a loose wire.
Test light,Ground one end and the other to the solenoid,yel/blk.Have someone turn the key.If it lights the tester and doesn't start then it's possible sol.is bad.Test the main lugs on sol. the same way.
foodfisher
Make sure the shifter is properly positioned. Could be the neutral safety switch is being activated.
1983rinker
That what it was. I put new LU in on saturday and had to adjust cable. So I look at my book the moring, and i followed all wires. And I seen the neutral safety was out of linement. So I move it and presto.. Tanks everyone for your help..
