I have a 2002 bayliner with a 3.0 mercruiser. I was running it today and had no problems...until the end. I turned the key and it cranked for 2 seconds and then stopped. Now, it will not crank or do anything. No click noise. I checked the fuses, but they seen ok. When I turn the key to the "run" position, the gauges all function. <br /><br />I used a dummy light tester and check the ignition switch. The light lights up when I turn the key. <br /><br />Also, I was able to arc the sylenoid and it made several clicking noise.<br /><br />Do you have any idea what I am missing? Is there another safty fuse somewhere? Is the starter bad?
