not starting(or cranking), gas gauge pegged
CaptCrabby
Hi
I have a 1987 70 hp
I was starting it when the engine stopped cranking and my gas gauge needle pegged when in the on position. Does this sound like an ignition switch or something on the motor? The motor will not crank with the switch. I ran jumpers to the starter and it cranked fine.
What would make the gas gauge needle peg?
my suspects are the ignition switch or maybe a soleniod
The battery is fully charged
Thanks for the help
CaptCrabby
CaptCrabby
Re: not starting(or cranking), gas gauge pegged
checked the switch with multimeter it seems to be ok
neutral saftey switch is good
Is there a connection at the instrument cluster that may be bad?
sigma
Check all your ground connections
CaptCrabby
Thanks Sigma
You were correct, I found a bad ground.
sigma
Thank you. Gl:cool:ad it was a simple fix
