Here goes: I have a 115HP year 2000 Merc. When it's cool outside, everything is fine. But once the motor sits under the hot sun, say 75 degrees or higher, it runs like hell.<br /><br />It always starts fine but when I power-up under load, the motor will run for a few minutes then misses, runs real rough, and eventually quits. It always restarts. The hotter the sun, the worse it is. (When it's not so hot, it won't fail until high RPMs, when it's a very hot sun, it will fail at much lower RPM but never goes solid-- it always restarts and idles.)<br /><br />They haven't been able to reproduce it in the tank. I think this owes itself to the need for heat build up under the cowl and the fact that it seems to fail under load.)<br /><br />Three times I've taken to the shop with no success. I've tried different plugs. I had them replace the stator. I've tried electronic part "cold spray" on the four CDM's and the<br />voltage regultor. No change. Would the trigger be a likely candidate for the offending part?
