Nova chips
Maxamus137
Has anyone replaced there points and condenser with nova chips to make a electronic ignition on there outboard motor.
Faztbullet
I used to do my duck hunters years ago but used the Serria(Atom) modules. They worked great on old motors that had worn armature plates...
Maxamus137
Thanks, I'm thinking about it on my old Johnson 6hp, if it works I'll use them on my 18hp evinrude
RCO
The old red atom modules worked fine on the OMC magneto ignitions, but they are NLA. The Nova II modules will usually fail in short order. The points and condensers are pretty reliable, and readily available. Why do you want to switch?
oldboat1
Recently been working through inboard distributor options -- wonder if parts from one of those electronic conversion kits could be modified to work with an outboard. (suppose not)
Maxamus137
I'm tired of mess with points. Pain in my butt. I guess I'm just not good at it and cant afford to take to a shop
