I've got two questions regarding getting power to my coil as there are two power sources & they're both dead. It's my '76 140 mercruiser.
1) I've lost power from the key switch thru the resistor wire. I've got power on the wire (white wire) from the key switch to the gauges & coming off the last gauge & into the harness but nothing at the other end. I'm not going to cut open the whole harness & was just going to run a new wire from the helm back to the engine. Can I get a new resistor wire, or do you have to replace it with a ballast type resistor?
2) my solenoid is not sending power to the coil during cranking neither. I was looking at a buddies boat this morning which is the same 140 set up as mine & his 12v to the coil during cranking is coming from the slave solenoid & not the starter solenoid. It's on with the big yellow wire that goes to the starter solenoid which is 12v during cranking also. He said he's had this boat for over 20 years & it must have been that way when he got it as it's never been to the shop & he didn't do it. Is this an ok alternative to getting the cranking voltage from the starter solenoid? Apparently it works or at least has for him. What, if any, long term problems could that setup cause. Supposedly he hadn't had any problems with his boat starting or running & they run that thing almost every weekend. Thanks. Jim.
