Nissan Newbie
- Jul 13, 2011
- 33
I have read almost every thread on this forum and can't find my question. Correct me if I'm wrong of course. I am new to this motor and outboards in general. The only way it will start is with starter fluid (I know its very bad for the motor) will run for a second and die. When I got the motor it was completly seized. I soaked the carb and put penetrating oil in the cylinders. Everything was freed up. I have checked the float needle (cleaned and moves fine), replaced the spark plugs, fuel filter, engine side gas line connector, fuel line with primer bulb and fuel tank. I filled my new tank with 89octane with a ratio of 50:1. I pulled the bottom spark plug and hooked up a compression gauge (60) and repeated on the top cylinder (49). Before you tear me apart, I don't have any mechanical exp. I just want to take my boy fishing. Thanks in advance! Any help would be great.
