thebobbykey
- Apr 30, 2012
- 9
I need some help . I've got a 1992 ns90a with a dead #1 cylinder ( top cylinder ) .I can pull the plug wire and there is no change in the motor, but the other two cylinders have a very noticeable change.
The compression on #1 = 135 psi , #2 = 133 psi , #3 = 134 psi .
If I get the plug boot close to the plug the spark will jump out and hit the plug ( so ive got spark ).
I've swapped out the #2 coil to the #1 cylinder still dead.
The plug has gs on it when I take it out ( so Ive got gas )
I've got new plugs and cleaned the carbs.
What else can it be?
