NSF9.8A2 Fuel Pump Issue
Bullie
I usually stick to my old Evinrudes and Johnsons but a fellow asked me to see if I could get his 9.8 Nissan 4 Stroke working again. I have a very similar, if not the same, motor that my dad uses, a 9.9 Mercury 4 stoke. This fellow had let someone borrow his motor and that person left it laying on the wrong side for a couple days. I have dealt with the same issue with my motor. Anyway, I cleaned the carb up and reinstalled. Before installing the new gas line from the fuel pump to the carb, I gave the bulb a few squeezes to move any old gas out of the line. No gas would move through the fuel pump but it was being pushed into the filter. I pulled the line entering the fuel pump off and gave the bulb a squeeze and fuel shot out as expected.
Is the fuel filter on this motor reasonably easy to rebuild? Is that what it sounds like I need to do? A new one is $57 plus shipping but if I can fix it I would rather do that. I am not familiar with this design but sort of surprised I couldn't push fuel through it.
What do you recommend?
pvanv
If you are priming and getting flow, but no gas to the carb, a diaphragm in the pump is blown, and you are dumping gas into the oil. If it's just pressurizing the inlet to the pump, a valve is stuck. Yes, new pump parts are available.
If you have the original pump for an A2, there have been 4 revisions/improvements since then. The latest pump is 3H6040007M, with an MSRP of just under $64.
See your Tohatsu dealer.
Yes, it is identical to the Merc 9.9, aside from a slight difference in carb, and possible shifter linkage difference.
Bullie
I took it apart and cleaned it up. The intake side was completely plugged. I likely need a new diaphragm but it wasn't stretched. I think I will give it a try.
Bullie
The carb interior looked pretty similar to the fuel pump. I cleaned everything up well and disposed of his old gas, it was bright yellow, and it runs like a new one again. Thanks for your help.
Bullie
The carb interior looked pretty much the same as the inside of the fuel pump. Leaving a 4 stroke laying on the wrong side is a bad idea. Anyway, after a good cleaning everything is working as it should and the little Nissan is purring again. Thanks for your help.
pvanv
The condition of the pump and the carb has NOTING to do with which side it was laid on. That's just plain old, bad, spoiled fuel.
