have a 84 Johnson seahorse70 hp. Everything works great ,got 5500 rpm on the wot. the idle is fine to when u start it ...Its just when u put it in gear rev or forward then back into neutral .. That it idles too high bout 2000rpms.. I then have to take the cowl off, and manually move the rocker arm about 8mm back to the idle speed screw. Then start the engine and it idles fine... turning the idle screw does not work ,ive already tried that..When I do that it idles to low or idles to high ,still leaving that 8mm space ,between the rocker arm and the idle screw... plezzzzzzze help!! Sick of taking the cowl off every time..ANY ADVICE WOULD BE GRRRRREAT!!!:facepalm:
