I have a 1999 Merc 25 hp ELF on my bass boat. I have never had a problem with the prop, but today I went to check the prop shaft for fishing line, etc. All was well, and after I greased the shaft I used a tire iron and a piece of wood to tighten the prop. The nut would seat on the shaft OK and got to a moderate tightness level, but then the nut would slip. The nut backed off fine but upon trying a second time, the nut would slip before getting ?real? tight. My impression was that the nut should be very tight to secure the prop. As an aside, last Monday I had the boat out and ran around a large lake at speed for about 45 minutes with no issues. Do I have a propeller problem in the making here?
