alley mechanic
- Apr 15, 2011
- 100
hello every body, I have a question about the o ring under the impeller when you push it down the drive shaft the manuel says to lube it with triple guard grease I have done this every water pump change but due to some issues here at home I had to leave the water pump assembly till a later time , what has happened I forgot to lube the o ring and didn't think of it till I had it put back together will this cause a issue wearing out right away. thank you.
alley mechanic
alley mechanic
