Object? found in bell housing exhaust port
stujr
Alpha one gen 2 (2004)
Removed Stern drive and found an object wedged behind the shift shaft. What is it? Should I remove it?
I didn't see it called out on the exploded view ofIMG_20230520_120805414_HDR~2.jpg the bell housing in Service manual #14
Thank you,
Stuart
Fun Times
One name for it would be exhaust flapper as there are a few names for them, which is about the same as you will see in the following thread linked,
frostystorm
Cool, now you need to replace it. It's a pretty important part. When there is no exhaust coming out of the engine that flapper shuts the exhaust tube and prevents a swell or wave from pushing water up into the engine.
Run without it, get stranded, replace at the very least the head of your engine at $800 in parts alone. If you have a 3.0L 4 cylinder, they aren't terrible to replace, once you get into the V8s though, real PITA.
