Hi,
Getting the boat ready for the summer, and I have had some problems getting the starter to go. I've only had the motor for a year, and it has had this problem as long as I've had it. But it has always started after a few tries until today. Today I tried several times all afternoon and all I got was a solid "click" from the solenoid and nothing from the starter. Here's what I've checked:
- cables are all good, no corrosion, contacts clean
- solid 12.6V to solenoid when trying to start
I tried to check voltage at the starter, but almost every time I tried, the starter engaged and I got 12.6V -- which is why periodic faults are so infuriating! The one time it just clicked I wasn't expecting it and not paying very close attention, but I think I saw a "mV" (millivolt) reading on the meter.
So my questions are:
- does this appear to be a failing solenoid?
- do solenoids fail this way (work fine most of the time, but occasionally not at work at all)?
- if it's not the solenoid, what is the next most likely culprit?
Thanks,
Lewis
Thanks,
Lewis
