Ocean Pro lower unit question
vdimenna
I have a 1996 Ocean Pro 200. Took the lower unit off the other day to change the pump. I noticed the input shaft had left to right movement. Does anyone know if this is normal or is this an indication of a a bearing failure? There wasn't any up and down movement. Only left to right. Everything spins smooth and shifts fine.<br /><br />Thanks <br />Victor
Dhadley
Re: Ocean Pro lower unit question
Some side to side is perfectly normal on a two piece shaft.
