- Mar 8, 2009
- 42,671
Getting the materials together to vinyl side our rental house. The house has 2 octagon non-opening windows. They are wood and the molding extends out more the the J-channel.
I want to cover all the wood I can to seal it up, and I have a aluminum brake. I can bend 8 pieces on metal, and try to overlap each and use sealer of some sort. This will take some work and I'm not real sure I will like the outcome.
Thought about removing all of the exterior wood molding and then place aluminum over and around the window, then install J-channel around. Could also install Plastic trim around the window after removing the wood trim, seal and go with J around it.
Most octagon windows have a square hole which has had 2x installed to make it 6 sided. Could remove and replace the windows with a square one, but really don't want to go that route.
Anyone have any opinions?
Other forums that deal with this kind of stuff?
