Re: Octane levels
Higher octane fuel just results in more carbon buildup in your engine over time. A tank or two won't hurt anything.<br /><br />If you are worried about it, just get some decarbing chemicals and decarb the motor so you know everything is good and clean inside. If you are unsure re "decarbing", do a search on this forum and you'll probably be able to read about it for an hour or two.<br /><br />Good luck!
