- Jul 18, 2011
- 18,285
I did some cleaning and checking through everything on my new-to-me O'Day Mariner (Sail #3224) over the past few days. The boat has 'positive flotation' via foam-filled chambers in the bow (v-berth) and the aft-berths.
V-berth area
Aft-Berth area (one on each side of the hull . . .
I drilled into a few of these chambers near where they meet the hull to see if the foam was retaining any water. Sure enough, along the aft berths and a small area of the bow, there was water in the foam.
Moisture and a little bit of water from these holes . . .
The aft berth fiberglass essentially constitutes the stringers for this boat, and as far as I can tell, there is very little wood in this boat to worry about. . . a bit in the transom and a couple of stiffener strips on the cabin top.
Lots of water from his hole . . . it is a pad area where the porta-pottie goes. The fiberglass in that area has a lot of gelcoat cracking, which would indicate freezing and expansion during the winter.
There are a few inspection holes with caps (orange plugs in the photos) and a few are missing, so that may have contributed to the water migration.
The v-berth area was dry . . . no water from this hole
In general, the foam that is visible from the inspection ports, being 40 years old is pretty much dried out and shrunken. So, I am thinking I should re-do the foam in this boat.
"Plan A" - would be to cut open a large enough area in the aft berths and the v-berth, remove the old foam, replace the cut-out areas and then re-load the foam via the 2-part pour-in urethane foam. I may add some areas of foam to give the boat a more positive amount of flotation.
The good news is that I found a 1 gallon gas jug way in the stern trapped under the cockpit seat. . . still some gas in it . . . not sure how old it might be, but it was liquid and not jelled looking :noidea:
Thoughts or advice for "Plan A" ???
Thanks in advance :thumb:
V-berth area
