OEM Starter solonoid - 1980 Merc Inline 6 115hp
hempfarmer
Hi there,
Would anyone where I could find the OEM part number for the starter solonoid? My motor and manual are a few hours away from me.
Also, anyone the life expectancy of a starter solonoid? Base on my records the one I have is 30 years old. Would they typically just die on you or just give you intermittent connection problems?
Cheers!
Russ
latin monkey
Re: OEM Starter solonoid - 1980 Merc Inline 6 115hp
from my experience the connections tend to loosen up and the posts will sometimes strip inside the plastic housing
Borchik
There are 3 different serial number ranges for that motor and all of them use different solenoids, to get the correct one you need a serial number or the part number off the old one.
hempfarmer
I should have that serial number, is there a resource I can reference for this information?
Thanks!
merc850
I had a bad solenoid that clicked but had no continuity between the large posts so I drilled out the four rivets that held it together and found inside a large copper disk. The disk makes contact across two copper points and was corroded, so I cleaned it with a dremel wire wheel tool. I reassembled the unit using RTV and the original gasket and replaced the rivets with stainless steel screws. It works fine and I can disassemble if I need to. You could use stainless rivets if you wanted to!
I did this just to see if I could.
