# of Drains
SteveRay
Want to make sure I don't miss any drainage for my winterize.
I have a '92 Mercuriser 3.0L and I found 2 drains on the port side, one on the block and one on the manifold (very close to each other).
Am I missing any?
Re: # of Drains
Ayuh,.......
Be sure to pull the Big Hose from the Waterpump, under the T-stat,......
And,.....
If you've got P/Steering,.... The Cooler needs Either of the Big Hoses removed from It.......
Not a Drains really,... But they Need Drainning.....
Btw,...... You Did rod out the Drain Holes,+ Got a Good Quanity of Water out,......... Right,..??..??......
SteveRay
Re: # of Drains
Thanks Bondo....Yeah I did do that.
I also plan on flushing with -50 Ban Frost after draining.
Of course I will fog, stabilize pull the drive,etc.
I should be good with this procedure correct?
Re: # of Drains
I Don't care for the use of Pollutants,..........Nor Wasting Money on them..........
Remember,......... Air Doesn't Freeze...........
Have a Look at the new thread about Winterizing by Don,........
It explains everything Real Well.........
