Re: Off the wall question on toons.
There is no average since the weight of the engine and how the boat is loaded will determine what the freeboard is. However, you can go to any boat dealer or marina and check the water line on any pontoon. You will find at the very back end of the tube, the water line will be roughly in the center of the tube. Add half the diameter of the tube, the riser height, and deck thickness and you will have your answer -- for that particular pontoon. If you are thinking I/O, it's already been done. If you are thinking jet drive, it's already been done. If you are thinking jet drive inside each tube, it's already been done. If you are thinking "V" drive, I would wonder "why".
