off with its head?
dixieguy
well the saga continues 1986 gm 3.0<br />previos post's were flapper valve and ignition probs.<br />this thing really has me baffled. still popping thru the carb. flapper vavle was non existent. new one will be here tues. old one was in the bellows.<br />Nice blue spark on all plugs.<br />I decided to run a compression check.<br />cyl1 160psi<br />#2 70 psi<br />#3 160psi<br />#4 165psi<br />I put a little oil in # 2 an dit went to<br />75psi<br />Do you think I found the problem???<br />Thanks in advance
Re: off with its head?
Yep.......<br />You've got a Bad intake Valve in #2 cylinder....<br />That's where the popping thru the carb is coming from.....<br />Pop it off,+ drag it over to your local MachineShop.....
