Ohh nooo a leak on the motor!!!
drewmitch44
115eltj. I Just found a tinny little spot where there is water coming out from the powerhead! In the picture there is a bolt dead center of the picture. Just under it in the picture there is some discolored paint and that is where the water is seeping out off. I didnt want to even wipe it off because it might get worse. Is there anything i can get to seal it up??? This really upsets me because this is a new to me motor. Im not sure what to do. Id does not come out fast at all it just is barely enough to pool is that spot. I dont want it to get worse Help!!!!!! JB Weld??? Help!!!
drewmitch44
Re: Ohh nooo a leak on the motor!!!
Forgot the picture!! HELP!!! Is there anything i can put on the leak to seal it up??????? There is no seals or gaskets where the water is coming from its just coming through the metal!!
drewmitch44
This is the same pic i just circled where im talking about its not the seal where the bolt is its where it gets flat i think its the block. I dont even see a pinhole there just a tiny bit of water pooling up.
