I have an OMC Cobra Lower Unit. I have a problem that is not normal. I pulled the lower plug in the lower unit to look at the oil and all that came out was alot of water then oil about 2Qts water/1 Qt oil. Started looking around the lower unit and noticed a tear in the Shift/U-joint boot and coming out of that tear was water and oil. Then I pulled the cover off the top of the upper housing and found alot of small peices of orange rubber that look like if came from a O-ring or Seal but from where? Please Help!!!!!!
