Oil capacity question. 1993 4.3 mercruiser
AMSOILGUY
So I have a 1993 Bayliner with a 4.3 mercruiser.SER#0F066078 I am changing the oil and I am not getting a reading on the dipstick. I called bayliner and everything that I have searched online says it should take 4.5 quarts. I have 6qts in and its only just below the ADD mark. I know it can't take more then that the only thing I can think is the dipstick is wrong. I have a part number on the dipstick it reads 41092-1. Can anybody give me some input here?
Thanks,
Jacob
alldodge
Agree, manual 18 shows 4.5 quarts, and note to check dip stick. Give it some time, and if it takes quite a while to drain down, then may want to pull the valve covers and clean return ports
Edit: your bow isn't up high is it?
alldodge
Here is the dipstick measurements, in case it was replaced
AMSOILGUY
I sort of feel like a dumb ass! Now 4 hours later I pull the dipstick and it is over full of course. I'll take some out. Thanks for the information.
Definitely pull the valve covers and clean the oil return ports.
