Oil Change adapter
mtntrogger
Hey fellas I have a Volvo penta 5.7 stern drive. I need to finish doing a oil change this spring and need to find where to get that fitting that goes on the end of the dipstick tube. I understand that I will pump the oil out through the tube. I began to do so while I was winterizing however my pump did not have a screw on fitting that mated to the penta tube. I used a tube attached to the pump, once it started making a mess everywhere from leaking I stopped and figured Id get the right tool for the job before proceeding. I looked on this site but wasnt able to locate the tool. Im sure someone on here can point me in the right direction. Thanks in advance !
Ayuh,..... If the end of yer dipstick tube is threaded, 'n 'bout 3/4" diameter, it's a standard garden hose connector,.....
Lou C
photo310144.jpg female garden hose adapter. Like what I have on this pump...
