You have a unique way of pizzing people off that's for sure . . . my
opinion comment was regarding Cat's recommendations and the fact that the inside of the filter is the clean side.
Your hydraulic shock theory is neither fact, nor opinion, it is false. The filter flows, it does not shock, there are ports in and out. Where's the shock? The ultimate solution to this age old debate is a pre-lube pump, but you don't see that on mobile equipment of this size. But in your world the ultimate solution is personal experience, I have installed my filters dry on everything from a VW to a 15 liter truck engine and I've never had a failure. Does that make my experience more valid? And how the heck do you pre-fill an upside down filter on my 6.2 Mercruiser? Oh, but that's a gasoline engine and somehow I am sure that it is not relevant despite exactly the same design. And then I suppose you'll say diesel rod bearings need more lube and sooner due to compression or cylinder pressure. And then I will say ALL of that speculation is indeed opinion . . .
