GMTK
- May 27, 2016
- 164
Changed the oil on my 2004 4.3L GXI-E this weekend. First time doing it myself and thought I would just share a couple quick tips for anyone with a similar engine.
OEM Oil filter - part # 3850559
OEM Volvo Oil - part #21681795 (gallon)
OEM Volvo Oil - part #21681794 (quart)
You need 5 quarts of oil.
To get the oil out, you will need a pump. I chose a hand pump by Jabsco that screws on to the dipstick. I ran my engine for 15 minutes to get the oil warm (was 60 degrees air temp). Took about 60 pumps to get the oil out. Here was the only real issue - due to space constraints in the engine bay, I could not attach the pump directly to the dipstick. So you may want to get a small garden hose. I had a 4' hose that I used and it worked out great. Also, when you go to disconnect the hose, have some towels ready as it will drip. When taking the oil filter off put a bunch of paper towels under the filter as it will leak out when you pull it off. Lastly, clean out the area around the dipstick where the pump screws on, as oil will pool in this little area. I was able to fold a paper towel and get it in the area so it could soak up the oil.
Here is the pump I used: https://www.iboats.com/shop/boat-mo...-pumps/jabsco-par-oil-change-pump-manual.html
I recommend putting one end in some hot water for a minute to help it get over the nipple.
