I am stumped I bought a 5.7 liter 260hp mercruiser long block to put in a ski boat. Ran the engine on the stand and the oil was always real clean on the stick. Installed engine and have run on the hose for several at least (5) 5-10 minute intervals. Shut down and upon checking the oil on stick always clean. Today I am changing the oil for this weekend check stick and oil is clean begin to use the oil suction sump and notice it now appears to be coming out light brown. Dump the reservoir and start over thinking there was water in the suction device prior to my engines oil. Remove the remainder of the engine oil and it is milky. Reinsert / Check the stick and it too is all milky, heart sinks and I reach for a beer. Engine did sit for two years before I got it. Can the engine be run without emulsifying water in the crankcase? Tomorrow I will flush change the oil and filter run the engine and recheck. The oil level never rose in the time I have run the motor nor did it turn milky until I inserted the suction device and began extracting. Half thinking I should have left the old "clean" oil in and gone boating as the oil has always been clean and clear until I went to change it.
Any thoughts? suggestions appreciated
Brian
Brian
