oil coming out of blower; cant plane
Status
Not open for further replies.
hammer97
Okay guys howguys how about this one: I couldn't seem to plane off yesterday and when I slowed down and turned on the blower in the engine hatch I had some type of oil/lube shooting out my blower vent. Any thoughts? Its a bravo one merc 454.
Many thanks!
Bifflefan
Re: oil coming out of blower; cant plane
First thing id do is pull the engine cover and look to see what is in the blower hose.
Then go from there.
You really didnt give enough info for a better answer.
zbnutcase
Could be anything...motor oil, drive oil, trim oil, steering oil, trim tab oil....
HT32BSX115
Um, yeah. If you look under the hood, you'll probably find oil EVERYWHERE!!
My first thought.......cracked block. oil level very high.....high enough to cause it to dump most or all of it out the breather tubes.
If you're wondering what the problem is and you have not raised the hood and looked inside.......Your best bet might be to drag the boat over to a Mercury dealer. Bring LOTS of $$$.
Sorry about that....
Rick
jtmarten
Master Chief Petty Officer
RANT ON
If you haven't even looked in the bilge, and it sounds as if you haven't, how could you possibly expect us to diagnose this???????
Get real.
I'll take a stab at it - the oil is coming from an item in the bilge that is, or used to be, lubricated.
Tea leaves, tarot cards, and magic 8-ball confirmed!!
RANT OFF
HT32BSX115
RANT ON
Get real.
RANT OFF
It's always good when someone else says what we all REALLY want to say!!
hammer97
Cracked block..bbbbhaaaaaaaa
Of course, I looked under the hood and there wasn't oil all over the place. I was just looking for some thoughts here, but all I found was a bunch of *****holes. Last time using this forum.
fishinpa
Ouchhhhhh :confused:
Ayuh,.... Dude,... The forum can only respond to what you Write, not what yer Thinkin'....
The above responses are Dead-On....
You provided No Info,+ your post States nothing of Lookin' at the motor....
If this is the Best you can do,.... Don't let the door hit ya in the arse....:p
Status
