Oil contamination???
bijou22
I recently changed the oil on my boat but overfilled it slightly, so the other day I started to drain some oil through the dipstick via a pump, but the pump had some contamination of sea water in it because I used it on a previous job. I have now found out that the crap in the pump (oily water) has entered the engine oil because when i check the oil, the dipstick is cloudy. Should I drain and fill again? or leave as is? or maybe add an additve to help?
rickdb1boat
Re: Oil contamination???
Drain and refill. You don't want to run it with any water contamination in the oil. Change the filter, too....
