Oil cooler leak on a AQ170 Volvo Penta
alaska scott
I have a leak on the intake tube of my oil cooler. I tried to relace the sealing ring with an O ring and also used a little form a gasket to help seal it . The following day it did not leak, but as soon as I brought it to the lake to test it out it started spraying water out and over heated the engine. Luckly I shut it down quick enough and no damage done. How can I get this to stop leaking??? Thank you for any advice.
kenny nunez
The water side of the oil cooler may be clogged up and not letting water flow through it, causing a back pressure .
