Oil drain hose
Surffx
Anybody have a newer Mercruser 3.0 liter? This would be the one that has a hose connected to the oil pan. Supposedly this hose is will come out of the bilge through the drain plug hole and then you can un-cap it to easily drain the engine oil. The problem with mine is I can’t seem to get it[the hose] all the way out of the hole. It just doesn’t want to fit, sure looks like the hole isn’t big enough to accommodate it. Nothing major I guess, just though I would see if anyone else had this problem.
jeff13601
Re: Oil drain hose
I dont know about the kits. I bought a funnel and some gas line and made one.
Bt Doctur
Re: Oil drain hose
never heard that, just connect the pump to the end of the hose and suck it out.
maxxpower
Re: Oil drain hose
Mine went through kind of hard but it did go. I just grabbed the metal tether cable with a needle nose pliers and pulled it through.
