Oil dripping from exhaust exit
flournoyg48
I’m trying to get my boat back running and today it finally cranked but after I turned it off I saw oil coming out of the exhaust exit at the back.
3.0 mercruiser engine
Do you have power steering? If so, check the pump reservoir
Scott06
Was it fogged before layup? Also do you mean out the prop hub or idle relife ports on transom housing? If prop hub could be gear oil from drive
