Oil Extractor
HPLou
Good day,
I want to remove the old oil in my Twin 4.3L Merc. With those Manual Oil Extractors it takes for ever to pump all the oil from both engines.
I have a 12v Fluid Pump that I can use if possible.
My question is;
If I remove the Oil Dipstick from the Metal Tube and use the right size of hose to fit this metal tube on the outside & tight with a collar;
Will I be able to suck the oil from the pan ?
Bt Doctur
thats what I do with the manual pump.I have a hose adaptor that slips over the dipstick tube instead of using the threaded fitting on the dipstick tube
alldodge
+1 and will add, let the motor run long enough to warm the oil (not full operating temp) and it comes out much easier with manual or electric
HPLou
Thank you guys.
You have saved me some time. I will work on my setup and reply back with results.
