my 200 hp 2 cycle Yamaha 2003 saltwater will not keep oil in the tank on motor. The level switch on the motor tank appears to be working as it drops engine rpm, and alarms. Override switch will cause motor to pump. Direct power to tank when out of boat provides plenty of flow from pump.
I have had very good advise on the wiring through one of the members, including wire colors, Brown carrying the power, Yellow in the main harness from the key switch supplying power to the circuit.
Emergency switch overrides both level switches and turns on pump. it runs. have removed external tank, changed filter. Found short in motor circuit and repaired it.
From my two other posts on this subject, I have one missing fact. If level switch in external tank is busted and says external tank is empty, will it keep the pump from running?
Can I override this switch. The level switch on the engine is the life saver.
I think this switch is preventing the motor from filling. If so should the two wires be connected or apart? Should I create a complete circuit or not?
