Hi, If I install a oil filter relocation kit and drop it into the engine compartment where the bilge is can this cool my oil. There is always water in there especially after a heavy rain storm. Could this work?
Thanks
You should be caring about your rotting boat before the oil temp is on the todo list!
Get the water out of the bilge, install a bilge pump with a float switch, and figure out where your leak(s) are. Water belongs outside the boat.
I checked the gauge sending unit and it was a little loose. I think that the pressure was escaping from there.
Where I was headed was that you don't need something new when a system begins to malfunction, you need to fix what's broked . . .I was loosing oil pressure yesterday and I was thinking that it was getting hot.
