Oil from the water intake
IanFS
Alpha 1 Gen 11
Hi guys
A colleague of mine has oil leaking from his water intake in his sterndrive, particularly when he lifts the leg. Do you have any idea where this may be from?
Could it be from the remote oil reservoir??
Could it be a gasket leak, is it something which can be diagnosed?
Cheers
Don S
Re: Oil from the water intake
Not the reservoir. Pull the outdrive, drain the gear lube, pressure check the drive and listen and spray some soapy water in the front area of the drive. You can usually hear the leak.
achris
More fish than mountain goat
As Don said, pressure test.
Oil from the water intakes can mean one (or more) of 3 places.
1. Shift shaft seal
2. top box lower seals
3. drive shaft seals (under the water pump).
Only a pressure test will determine exactly which...
Chris..........
Alpha 1 Gen 11
Hi guys
Cheers
Ayuh,.... As noted, more likely a seal, 'n easy to diagnose, once the drive is on the bench....
IanFS
Thank you all so much for your relpies, I'll pass them on. :)
